INDEX, Steel, weld, carbon, mild, tempering, tool, bulbs, welding, hammering, Sulphur, coal, surface plate,
Swages, Swaging, Swedish iron, Tire-measuring wheel, T- weld, Tong, reins, fire, twisted, forged, steam hammer,
——, how to forge, 30
——, how to keep, 35
——, making a  rivet  for,  33
——, method of forging,  31
—— required    for   the    forge-shop, 30
—— should    be    forged,    not filed, 31
——, size  of,   to  use  in  forging, 34
——, various  forms  of,  29 Tool for twisting flat  bars, 82
—— steel,   28
——, top,   for   modeling,   138, ;    139
———, truing,   144 Tools,  anvil,  35,  36,  37
——, banding,   105
——, embossing,   134
—— for embossing, 137
—— for the forge-shop, 30
———, heavy  and  light,   38
——, special,   24,   38
——, swaging,  81 Upsetting by   ramming, 43
——, definition of, 41
Upsetting, methods of, 41, 42 Top    tool   for   modeling,   138,
139
Truing-tool, 144 Traveler,      or      tire-measuring
wheel, 49 T  welding,  56 J.
INDEX 197 Steel can be welded, when, 28 --, carbon in, 28 Steel, mild, 28 --, tempering, 28 --, tool, 28 -- used in making bulbs, 94 --v welding soft, 52 Steps, hammering the, 54 Sulphur in coal, 24 •• Surface plate, 109 Swages, 35, 36 Swaging, tools used in, 81 Swedish iron, 27 Table-top, frame for a, 149 Tempering steel, 28 Tire-measuring wheel, 49 T jump weld, 66 Tong handles or reins, 30 -- --, to smooth, 34 Tongs, fire, of twisted stock, 83 -- forged under a steam hammer, 34 --, how to forge, 30 --, how to keep, 35 --, making a rivet for, 33 --, method of forging, 31 -- required for the forge-shop, 30 -- should be forged, not filed, 31 --, size of, to use in forging, 34 --, various forms of, 29 Tool for twisting flat bars, 82 -- steel, 28 --, top, for modeling, 138, ; 139 ---, truing, 144 Tools, anvil, 35, 36, 37 --, banding, 105 --, embossing, 134 -- for embossing, 137 -- for the forge-shop, 30 ---, heavy and light, 38 --, special, 24, 38 --, swaging, 81 Upsetting by ramming, 43 --, definition of, 41 Upsetting, methods of, 41, 42 Top tool for modeling, 138, 139 Truing-tool, 144 Traveler, or tire-measuring wheel, 49 T welding, 56 J." weld with round iron, 57 Twisted bar, section of a, 81 Twisted links, 73 Twisting a bar, 77 -- flat bars, 85 -- -- --, tool for, 82 --, hot and cold, 78 --, methods of, 78 -- the bulb, 94 Twists, spacing of, 77 --, spindle-shaped spiral, 90, 91 --, spirals, etc., 77 Two-light candlestick, 130, 131 Weld, end-to-end, 56, 57 --, making a jump, 65 --, T jump, 66 Welded joint, the, 60 -- scrollwork, 122 Welding, 51, 64 --- bands, 69 --, butt, 67 --, cross, 61, 62 -- flat rings, 68 --- hoops, 69 ---, jump, 64 --, lap, 56 -- links, 74 --, many kinds of, 53 ---, ordinary ring, 70 rings of rounded stock, 69 -, scarf, 53 scrollwork, method of, 123 --, T, 56, 61 Welds, corner, 56, 62 Wheel, tire-measuring, 49 Working up a ball, 102 Wrought iron, 27
