196
HAND - FORGING
Punching,  cold, 45 Punching heavy stock, 44
—— light stock,  45 Quenching bath, a good, 30 Hamming, 42
——, upsetting by, 43
Eaised   form,   pattern   of,   155
—— forms,   150,   154
——— ——y block  used  in  making,  153 Raising a form, method of, 153
—— by bumping,  154
——, hammer  used in,  153 Rectifying a bulb,  98
—— a   scroll,   110,   112,   113,
117
Reins, or handles, of tongs, 30 Relief, modeling in,  134 Ring,   binding  the   tongs   with
a,  33, 34
——— on end of bar, turning a,
70	..'-.-;.•   V      •   .
—— welding,   ordinary,''70 Rings of flat stock, 70    ;
—— of rounded stock,  6ftv:-
——, welding flat,  68 Rivet  for tongs, making ,£, 33 Riveted scrollwork,  108 Riveting,  105
—— braces  on lamp  standard, 189
——, methods    of,    illustrated,
106 Rivets,  drilling holes  for, 122
—— for lamp shades, 191
——— in   tongs,   31 Rivet  set,  105
Rosette,  design for a modeled, 136, 137
——, modeling a,  139 Rosettes,  150,   151 Rusting,  to   prevent,   158 Sand  as flux  in  welding,  52 Scale prevents welding, 52 Scarfing, 53 Scarfs, around small bars, 59
——, lapping   corner,   63
——— on corners,  62
——— to  fit bar,  forming, 56 Scarf-welding,   53
Scroll ends, 121 Scroll, forming a, 109
——, forming  the  body   of  a, 112
——, method    of    forming    a,
114
—, rectifying   a,   110,    112,
113, 117
' 'roll-and-twist grille, 87 Scroll-bending, former for, 111,
114 Scrolls, combining,  109
——, methods of  shaping,  108 Scrollwork,  108
——, drafting-board for, 109
——, grilles   of  flat,   115,   118
——, method   of   welding,   123
——, welded, 122 Set  hammers,  35,   36 Shade, detail of lamp, 183
——, drawing for lamp, 180
——, lamp,   how   to   make   a, 179
—— of   twelve   sections,   190
—— with drop sides, 191 Shovel  bowl, 154
—— of   twisted   square   stock,
83
Shrinking bands,   49 Sinking-tool, 138 Slag, definition of, 27 Sledge,   use of the,  38 Small work, welding, 56 Solid forgings, 48 Spacing of twists,  77 Spelter,  75 Spindle-shaped     spiral     twists,
90,  91 Spirals,   20,   77,   90
———, method   of   forming,   90, 93
———, ovals  and circles, 20 Spiral    twists,    spindle-shaped,
90,   91
Splitting the end, 55 Stand for fireside set, 83 Standard   for  lamp,   detail  of,
187
——— —— ——.,   how   to   make, 185
196 HAND - FORGING Punching, cold, 45 Punching heavy stock, 44 -- light stock, 45 Quenching bath, a good, 30 Hamming, 42 --, upsetting by, 43 Eaised form, pattern of, 155 -- forms, 150, 154 --- --y block used in making, 153 Raising a form, method of, 153 -- by bumping, 154 --, hammer used in, 153 Rectifying a bulb, 98 -- a scroll, 110, 112, 113, 117 Reins, or handles, of tongs, 30 Relief, modeling in, 134 Ring, binding the tongs with a, 33, 34 --- on end of bar, turning a, 70 ..'-.-;.• V • . -- welding, ordinary,''70 Rings of flat stock, 70 ; -- of rounded stock, 6ftv:- --, welding flat, 68 Rivet for tongs, making ,£, 33 Riveted scrollwork, 108 Riveting, 105 -- braces on lamp standard, 189 --, methods of, illustrated, 106 Rivets, drilling holes for, 122 -- for lamp shades, 191 --- in tongs, 31 Rivet set, 105 Rosette, design for a modeled, 136, 137 --, modeling a, 139 Rosettes, 150, 151 Rusting, to prevent, 158 Sand as flux in welding, 52 Scale prevents welding, 52 Scarfing, 53 Scarfs, around small bars, 59 --, lapping corner, 63 --- on corners, 62 --- to fit bar, forming, 56 Scarf-welding, 53 Scroll ends, 121 Scroll, forming a, 109 --, forming the body of a, 112 --, method of forming a, 114 -, rectifying a, 110, 112, 113, 117 ' 'roll-and-twist grille, 87 Scroll-bending, former for, 111, 114 Scrolls, combining, 109 --, methods of shaping, 108 Scrollwork, 108 --, drafting-board for, 109 --, grilles of flat, 115, 118 --, method of welding, 123 --, welded, 122 Set hammers, 35, 36 Shade, detail of lamp, 183 --, drawing for lamp, 180 --, lamp, how to make a, 179 -- of twelve sections, 190 -- with drop sides, 191 Shovel bowl, 154 -- of twisted square stock, 83 Shrinking bands, 49 Sinking-tool, 138 Slag, definition of, 27 Sledge, use of the, 38 Small work, welding, 56 Solid forgings, 48 Spacing of twists, 77 Spelter, 75 Spindle-shaped spiral twists, 90, 91 Spirals, 20, 77, 90 ---, method of forming, 90, 93 ---, ovals and circles, 20 Spiral twists, spindle-shaped, 90, 91 Splitting the end, 55 Stand for fireside set, 83 Standard for lamp, detail of, 187 --- -- --., how to make, 185
